horgantrevor
- Jan 14, 2011
- w202 c43 & w210 E220 CDI estate w219 W221
hi i found out what the noise was it is the bearing on the front of the water bump it is making a bad squeek when you start it up in the morning i sprayed it with chain grease for a motor bike to day and the nose went away but i could hear what i think is a faint noise of bearing
i also went out and striped an s class w140 m104 engine and the bump was teh same so i took it off to have a look it looks like the bearing in the front could be changed if i wanted too
also i see three bolts on the back of the water pump like an inspection cover or to remove the impeller am i correct if so has any one done this before
