W202 C43 drivers door check strap
andrewcliffe
Norwich UK
C43 AMG
Mine has started making a funny noise when opening and closing - any common problems with them?
Sounds as if its coming from inside the door.
Finally had time to check this out. The screws holding the check strap to the door were loose - easy 1 minute job. Checked the other 3 doors and they weren't tight either. I would advise anyone to quickly check theirs with a 10mm socket.
Fixed.
Could also be worth while removing the door panel and check the 3 rd bolt that holds on the check strap , this can come loose and even fall out
Apologies for bumping a very old thread, but my problem is relevant.
My door catch appears to have come apart inside the door, the two bolts on the door are not attached to the stay any more.
Is it more likely that they have just worked themselves loose and come away, or do you think the stay has broken? It all looks in tact, apart from the fact it's not attached to the door any more...
