safi-001 said:hi can someone tell me can i do this mod to my 98 c250 td esprit manual.
thanks.
1998K said:Ok thanks a lot Graham. This mod. seems cheaper as retrofitting than as factory option![]()
Have you seen if the stalk part comes with relevant cable connection?
My worries are about Mercedes Dealer...to find the right part number and STAR setting.
...since when I asked info about setting to "the Netherlands" in order to hear "CHIRP" closing the car, they said it's impossible, only at factory!...but I know someone have done it.![]()
GrahamC230K said:One tip - I have a stalk for Cruise which has the speed limiter controls - which do NOT work. However, there is a different part which is the cruise stalk WITHOUT the speed limiter bit - this would make a neater install.
1998K said:thanks this is really a nice point out.![]()
...any chance to have the right part number?![]()
I will try to look laterGrahamC230K said:No, sorry.
It doesn't neccessarily follow that modified or updated items will also appear on the 208 first thoughV12 said:It's from a 208 CLK![]()
Shude said:I will try to look later
I wonder if it's a '202 part or from some other model.
Note to self: the item will be listed as being for vehicles +440 +428 and possibly -420 -423 -425.
I don't have the info yet, I only have access to the data at home, last night I forgot1998K said:Thanks a lot Shude, I'll be at the Stealership in 1 hour, so if it is possible I'm wondering to bring me the part number you'll find out![]()
440 is tempomat (cruise control)1998K said:Otherwise I'll be back on the forum only next monday.
What's "+440 +428 and possibly -420 -423 -425"?
Shude said:I don't have the info yet, I only have access to the data at home, last night I forgot![]()
428 is 5-speed manual transmission
420 is 4-speed auto with cruise
423 is 5-speed auto with cruise
425 is 5-speed auto without cruise.
You need to find the correct combination of options, the cruise stalk will differ depending on which options were fitted at the factory. The catalogue just has a brief description and a line drawing...
Your stealership parts people could also work this out - they have more information than I do!1998K said:OK thanks so please I wait your info part number before visit to the dealer![]()
If you need mine is a manual so should be 428 code. If you need I can provide you other car data (i.e. boh! frame number,... I don't know).
I'm back as I can.
thanks again
Marco
