W202 dashboard lights
sam-orr
My the light on the right hand side of my dashboard has blown. Any ideas on how to get in and change a bulb?
C200
If you remove the lower dash panel on the drivers side reach up and simply push the cluster out strictly speaking the steering wheel needs to be removed but you can jiggle the cluster out, from memory there are two multi plugs one either side of the cluster.
The dash illumination bulbs simply twist out.
Source the new bulbs from MB as you need to get the right wattage (1.2W I think) the wrong wattage bulb fitted can cause parts of the cluster to melt.
