I have a quiery regarding eis on w202 would it be possible to put pre facelift ignition barrel if the eis is removed? Does the imobliser disarm when the doors are opened? Or when key is in ignition?
The EIS isn't a simple immobiliser. As Andy says, it's very linked to the ECU over the CAN.
Somehow you would need to send the appropriate CAN signals to activate the ECU and START and then the STOP cycle.
wont work, as far as i know the EIS knows the ECU and vice versa they come programmed up to you specific car from the dealers. There are companies out there that can do this for you.
Hi alps the problem is no one wants to touch them and the ones who can do it want stupid money. There was a company in the US who made a bypass for the W210 on a trail basis and got everything working I don't think there is any difference in the w210 and w202 system but that bypass was plug n play
