LastMinute
Ian's got a 1995 W202.125 C250 Diesel in The Works with a defective front passenger electric window. We've checked the fuse, the switch, the motor, the wiring and the comfort switching relay, and they're all OK - so that leaves the comfort control module (= box with 8 relays [one 'up' + one 'down' for each window] and some electrickery) as the prime suspect. This is an early W202 - i.e., before the days of CAN bus and door control modules.
There appears to be a stray 1.4V across one of the relay coils. It's not enough to pull the armature in, but is enough to hold it in once it's there. The coil resistance (measured in situ in the circuit assembly) is the same on the dodgy relay as on all the others.
A new module is £192, so we're looking for a lower-cost solution.
Any ideas for further testing or repair of the existing module?
Cheers
Cheers
