w202 - Engine Components Fuse
Discussion in 'Electronics' started by uhayat, Oct 25, 2011.
  1. uhayat
    uhayat Active Member
    87
    Dec 19, 2006
    Pakistan
    Car:
    w211 E200 Kompressor
    Hi all,
    Lately my w202 250D 1994 has been giving trouble in starting. The battery is being drained suddenly at times. If I drive the car every day it is ok but the starter does feel a bit lazy as if the battery is not fully charged. If I leave it for the weekend it will not start on Monday. The multi-meter shows hardly any current loss when I test with the positive terminal off. Replaced the battery but still the same problems. The alternator is good and is doing what it should - already had it checked.
    Yesterday I noticed the Engine Components fuse in the fuse box was burnt. Looks like there is a short as each time I put in a new fuse it just shorts. Does anyone have any ideas as to what the Engine Components fuse is? And which components does it give the current to? Any help in this regard will be appreciated.
    - Usman
Share This Page
