Did everyone read Koolvin's excellent article:puddle light mods complete (BIG PICS and VIDEO) ?
I tried this, and with help from Steve (MBenzNL) and the stealership I have almost finished. My car is now fully wired up and has all the bulbs, lenses and connectors EXCEPT ONE - the plug into the front dome-light. No-one has been able to tell me the part number for this plug, not the stealership, not Steve (EPC does not list it). I have now spent about £30 on wiring looms from the stealership and none of them have had the required plug! The plug will be about 50 pence ONCE I have established which one it it!
Please please please can someone with a 1997+ w202 ELEGANCE (which came with these puddle lights as standard) pull their dome light out and take a look at the plug for me?
Here is how to take the dome light apart...
1. Pull the frosted lenses off the domelight, they just unclip, you are now looking at this:
2. See those two holes to the left of the buttons etc? If you can, slip one finger into one of the holes and pull the light down slightly, two tabs against the rear of the light will become exposed, you will need to use a small screwdriver or your fingernail to release these.
The domelight will just fall out now, but will hang from the ceiling by a shedload of cables .
The front of the domelight has all the connectors going into it. I need the connector that has wires these colours going into it:
I need to see pics of the connector and which way around the wires go (although I think for bulb-lighting purposes either way around would probably work).
A pic like these would be VERY useful indeed!
Thanks guys, and remember: oem rulez!
