W202 front wings.
jasons
suffolk
w204 c220 cdi sport
Hi I have to replace my rusty front wings and I have purchased some pattern ones from ECP but I was wondering how do I go about prepping them before fitting like underseal/waxoyl do I rub the insides down or do I just put waxoyl on top of the black paint that they come as.what else do you recommend instead of waxoyl.
hondo
Truck bed liner (raptor/x-line )is brilliant but expensive ,it's the toughest coating I know of
Giv the inner wing a key with a scotchbrite or even Brillo pad brush seal round arch then stonechip the whole underside of wing this will b far cheaper
Once the wing is painted before u fit it to car drown the bugger in waxoyl
That should keep the rust at bay
guydewdney
Porlock, Zomerzet
906 Sprinter 313cdi
My 202 has had the rear arches 'rolled' possibly at new / factory / soon after. This appears to have massivly helped the corrosion. consider either filling the 'lips' with goo (sikaflex?) or rolling / beating them so they cant hold mud.
ringway
In a World of My Own.
2017 Audi RS6 Avant Performance Edition. Range Rover Supercharged - Lovely!
My current 210 has rolled arches and at 12 years old is showing far less corrosion (very little) than my previous one had a 6 years old.
Pretty sure mine were rolled at the factory as I seem to recall seeing it listed on the datacard.
hondo
Rolling the arch leaves no lip for salt n dirt to sit on soaking from autumn till spring but if you do it on the front wings especially pattern 1s you will loose a lot of rigidity around the arch
