W202 gearbox Casing!
funga007
london
Merc w202 200
I need a gearbox casing, i have a crack/hole i believe, have not checked yet. will do shortly.
car outside work with a large puddle of atf fluid, doubt ill be able to drive the mile home!
It will be easier to buy a whole gearbox as the casing is one thing, getting all the guts swapped over is serious doings.
Lynall
I'm Lynall,
Unless your a Auto box specialist, I'd try & locate a brand new second hand box
its still leaking but not from the case, i think the washer on the shift interlocking cable is cracked
Nice!! I'm guessing that a interlocking cable washer must be a lot cheaper than a re-con auto box :bannana:
