deian
Hi all,
(this was declared when I bought the car)...
Going through the service history, it shows the glowplugs were changed last time at 129k (it's done 179k) in January 2008, prior to that at 62k (no issues then).
When the job was done in Jan 08, it was reported that they were all ceased in, they were all changed but plug 3, and in Dec 08, there's a letter saying glowplug 3 has been cross threaded a little and wasn't put in too tight in case of further cross threading, but was sealing fine. I assume it's an aluminium head hence the cross threading.
Now it starts fine, it's rough when cold as glow plug 3 is somewhat negligible, it runs fine after about 10 seconds, and then fine all day afterwards.
IF I tackle plug 3, should I be prepared for cross threading on the way out? Should I tap a new thread or will that release bits of aluminium into the combustion chamber? (if I do, could I suck the bits out with a vacuum cleaner).
While I'm at it, should I open and release the other glow plugs as matter of course, and maybe put some copperslip on them for easy removal next time.
I will of course be careful and straight and slow with the opening/closing of the glowplugs, but I'm scared. Don't want to damage the head.
What would you guys do?
