W202 Leather Door Cards
omegav6i
Hoddesdon
C43
Still looking for a set of Leather Door cards if any are lying about out there.
Be sure that you get the correct ones as prefacelift and facelift door cards are different though they can be fitted it is,nt straight forward and may need additional parts and brackets fitted on the inner door to mount them, this is certainly the case if fitting prefacelift cards to a facelift car.
Fitting facelift cards to a prefacelift car is easier but does require brackets on the door to be drilled out and removed, and extra holes drilled to fit the door cards.
