No its not meant to condensate the windows. May be water trapped as the drains are blocked. Over time this will go stagnant and start to smell
put it this way a new cars air con system dose not condensate the car but over time as the system gets hot and cold it will produce a build up of water that water escapes out of drain holes if there blocked it carnt this will cause condensation when you use the systemHi
Are we talking about condensation in droplets or a light mist that initially comes through ?
Chris
Not much air coming through the ac, guessing the pollen filter needs changing. How much are these from mb? Seen some on eBay for £14.
Cheers
