Grey Area
Hi all. So, as I was stuck in boxing day sales traffic the car began to overheat to the extent that the radiator fan kicked in and the engine coolant level light came on. we're talking about 100-110 degrees on the temp gauge. When I (finally) parked the car and shut the ignition off I noticed that the fan was still running at full speed. I thought this was a little odd but that maybe it would shut off after a minute when the temperature had dropped a little (shows what i know). When I came back a few hours later the fan evidently hadn't shut off until the battery had died. As soon as I connected a jump starter pack to the battery the fan tried to start up again. Now it will not go off and the coolant level light is on even though the levels are fine and the engine is nowhere near hot. Currently have the fan unplugged which solves both problems but I would rather a solution could be found. Prior to this the car has never been a touch over 85 degrees in any scenario. Any help or advice would, of course, be appreciated.
P.S I'm thinking fan control module, any other ideas?
