if it fails the carrot test then the viscous coupling is most likely knackered.
It has a vicous coupling... what do you think it should do?
When it gets hot, the coupling locks and the fan comes on and your carrot will break in the carrot test. (you'll likely lose a finger too)
I think the fan cuts in at about 85Deg
my fan comes on even when the engine is cold started
If it spins freely when the engine is cold and switched off then it will also do the same when the engine is cold when running.
You've not actually tried with a carrot have you?
this vid shows that this guys fan spins as soon as he starts the engine
[YOUTUBE]UYaEwfhfOG8[/YOUTUBE]
