Ive noticed on start up and when sitting idle that there is a screeching noise coming from the engine area! Im assuming its the fan belt but is there anything i can do to stop it?? Does it mean that anything is on its way out???
It could be a fan belt! But I think they have auto-tensioners on them???? Maybe one of the guys on here who run Indis could clarify... Could be a seized water pump!
It’s possibly the fan belt if it is either worn, wet or has oil on it.
I had my belt changed 2 years ago, that’s about 11,000 miles approximately because of wear and slight cracking, it was possibly the original belt.
Very occasionally on a cold start I get a quick squeal from the belt, I put this down to excessive condensation in the belt area, damp day kind of thing.
Others may say it could be pulley wear but I don’t know enough about that to comment.
Obtain a very long screwdriver and put it on the water pump while the engine is running. Put your ear on the handle end, youll soon know if the pumps making the noise.
I realised it was simply the alternator being put under load! Went a two hour drive to give the battery some charge and never heard it again. :bannana:
300-24, saloon and coupe, E300 24 valve diesel estate
Put some talcum powder on the belt, if it stops screeching then the belt is goosed. If the screeching is still there then further investigation as above will be required.
