Feeble
Another day, another problem...
I've installed a pair of mid range 16.5 speakers in the front doors, using the correct spacers. Had to hack away a bit of the grille behind the speakers to get them to fit, but the windows still operate correctly as they don't protrude too much.
Just been out to look at putting the door cards back on after mounting the crossovers inside the door cards. Took the speaker off of its spacer to connect it up and the magnet has a lot of water on it.
Firstly I'm wondering if it's normal for water to be inside the door? The seals all look normal and undamaged.
Secondly, realistically, is this going to be a problem for the speakers? There doesn't appear to be any moisture on anything other than the magnet...
What should I do..?
What should I do..?
