W202 whining noise while driving
JimC200
Laois, Ireland
2004 w211 estate 2.2 cdi manual, 177k mls
I've got 98 c200 and it makes a funny whining noise that seems to be inside the cabin when driving in 3rd or 4th at a certain rpm, that is it comes in at 2000rpm then goes by 2.5 it stays even if I press the clutch in so I'm sure it's not a gearbox issue? The car drives perfectly so I'm not worried just a little annoying is all, anyone experience similar?
OP
OP
J
JimC200
Laois, Ireland
I had thought of that but is the diff up front? I thought it would be on the rear axle And why only whine at that really small Rpm range and only in 3-4th gear? It's a weird one
Monkeylegend
2011 E Class 220CDi, 2004 SL350
If it's coming form the nearside front it's most likely the wife. :)
That's the first thought that came to mind when I read the thread title, not much help I know :doh:
NW_Merc
Banned
Over here, sometimes over there
1994 Mercedes C180 classic
It sounds like a high pitched whine (the diff not the wife). Its particularly apparent as you slow from motorway speeds to coming to a stop. Is this what the noise is like?
The diff is at the back, where the driving wheels are.
horgantrevor
w202 c43 & w210 E220 CDI estate w219 W221
its not the wheel bearing also a common fault could it be they would be worse when they get hot
is the noise their when cold
DSM10000
Near Salisbury
E32O CDi Sport, MX5 1.8 Sport, RR 4.2 SC
I used to have an intermittent whining noise when driving although (possibly coincidentally) since the divorce it has ceased ;)
OP
OP
J
JimC200
Laois, Ireland
No mine is definitely upfront sounds like it's behind the glove box, I'm just going to let it go if something is wrong it will eventually break then I'll fix it :)
OP
OP
J
JimC200
Laois, Ireland
It's there only when moving from about 25-30 mph then nothing,
Hot or cold it's there
keljon
Plymouth
1998 w202 c230k
It's prob the wheel bearing but I would check the prop as well
OP
OP
J
JimC200
Laois, Ireland
Did a couple of 60 minute runs with the car fully loaded up with the family and no more whining sound, even after I went out by myself it was still gone, let's see if it comes back after sitting up overnight lol
millo777
Swansea, Dubai, Riyadh
1997 W140 S600L/2003 S211 320cdi
A whinign noise could be a number of different things, wheel bearing, diff, belt idler pulley, water pump etc etc I think you'll have to do some more investigation to narrow it down. Maybe try and get the car stationary and get someone to rev it to the range you've experienced the noise at to rule out anything belt/pulley related.
And the longest shot of all, if the whine raises in pitch with revs, it might even be alternator noise being picked up on the hifi. Unlikely I know, but it's always worth elminating the easiest things first.
OP
OP
J
JimC200
Laois, Ireland
Ok the noise goes away after a good drive, when it cools down and I go off again it comes back if it's only a short run it seems to stay, strange huh? I had a very strange issue with my blower fan also, I bought a new fan put it in and didn't work pulled it out whole still wired up and it worked, then stopped then input my old one back on and it worked! Screwed it back into it's mounts and it's fine now, all I did was wd40 the connectors, my car is strange lol
OP
OP
J
JimC200
Laois, Ireland
Ok I've decided it's not a whine it's more of a wail not metallic or grinding in any way its so weird, I'm going to put the car through the nct and see what they come back with, I noticed a tiny spot of oil on the diff the other day :(
