Hi, I just got a car and the clutch biting point is not far off the floor, which seems wrong and trying to hill start without a regular handbrake is stressful.
Because it's a fluid clutch I had it bled-out but it didn't change it much but as a fluid clutch should be self-adjusting I'm guessing the clutch itself is not the problem.
Q1) Haynes and MB show a special tool (like a fish-n-chip-shop fork) for using to test the clutch plate thickness; as I'm not a tool maker does anyone know where I can get hold of one of these?
Q2) Are the master/slave cylinders on these prone to wearing out such that they stop moving sufficient fluid/the clutch activator sufficiently, hence the low biting point?
Thanks in advance for your thoughts.
