W203 112 engine slight ticking front cover
Discussion in 'Engine' started by lynall, May 29, 2011.
  1. lynall
    lynall MB Enthusiast
    3,169
    Jul 31, 2008
    Kent
    Car:
    The silver one.
    Hi long time no post:doh:
    Wifes c320 usual detailed info from her it wouldnt start sort of not, im not really sure!
    So i had a poke around, nothing obvious but a light regular ticking noise from the front of the motor, it comes and goes cant hear it with the bonnet down and i dont remember hearing it before.
    So just to be sure i changed the oil full syn15/40
    Its still the same but to be honest i wasnt expecting anything else!
    History new syn oil every 5k, new plugs 25k ago along with all new leads
    Crank sensor last year
    So after all that waffle what do you reckon the noise could be?:p
    Lynall
  2. BlackC55
    BlackC55 Authorised Forum Sponsor Authorised Forum Sponsor
    18,922
    Feb 8, 2007
    Portsmouth, Hampshire.
    Car:
    E55K SL500 E300Hybrid E250X3 Viano C55 E450Cab A180 Smart 44 Brabus
    It's not the re-generation valve ticking is it?
  3. mobeyone
    mobeyone MB Enthusiast
    1,432
    Apr 23, 2005
    Car:
    E280 S211
    I had this too with my 203 and it was the valve, easy fix.
  4. OP
    OP
    lynall
    3,169
    Jul 31, 2008
    Kent
    Car:
    The silver one.
    No assuming you mean the valve on the nearside inner wing it has always ticked.
    Its different to that and defo seems to be from the motor.
    Lynall
  5. stevesey
    stevesey MB Enthusiast
    2,969
    Sep 3, 2007
    Bristol
    Car:
    Alfa 156 1.8TS
    N.B. Lifting the valve off the mount (so it's supported just by the pipes) reduceds the amount of "tick" transmitted through the body. Also I beleive PCV should be disabled for the first two minutes after starting.
    Std questions - Hot/Cold engine make any difference to your tick, and what happens if you blip the throttle?
  6. jefrs
    jefrs Active Member
    617
    May 30, 2010
    Berkshire
    Car:
    S210 E320 Avantgarde '98 full load
    Wife's Corsa makes a noise like a demented sewing machine. Vauxhall swear this is normal not to worry and due to the timing chain/belt(?) tensioner.
    Front of motor is MB timing chain.
    Syth should last more than 5k.
    Is there some reason you are using 15W-40 instead of 0W-40?
    Have you run flushing oil recently, this can clean out various hydraulic tensioners (timing chain) and valve lifters (tappets).
Share This Page
