w203 2002 elecric seat not working
brens-e200
naas, ireland
1990 230E W124, 1992 C124 220E
hi,
a friends 2002 w203 drivers seat electrics are not working . I have verified that the ground and constant 12 volts exist but not the switchable 12 volts. I have verified the fuses and all ok. The passenger side works fine.
I disconnected the loom as far as it would let me and while pulling on the switchable 12v cable could find no physical brake in the cable ( without been too rough on it ) .
My question is is there an easy 12v switchable location I could take a link from and feed it into the connector ( after first splitting the cable )
thanks in advance
brendan
Mike Walker
North Kent
Mercedes W204 C220cdi Estate Ford Fiesta Mk 4
Happened to me a while back and upon investigation found that a cable underneath and associated with the seat was pinched and cut partly through. Quick repair and all has been fine ever since.
OP
OP
brens-e200
brens-e200
naas, ireland
update
hi
thought my pal had checked the number 2 fuse in the boot but he had not :Oops: . the fuse was blown and once replaced initially the electric seat worked. then after a few minutes the few went again, so it was replaced one last time and it blew again.
so i obviously have something shorting. i see that there are 2 screws at the bottom of the cover that sits on the back of the seat. Once these are removed how do i remove the cover to inspect the motors which i assume are placed behind it ?
thanks for the help
brendan
OP
OP
brens-e200
brens-e200
naas, ireland
fixed
hi
just thought i'd let you know that after removing the rear seat panel i could see fraying down beside the motor ( on the lhs as you look at the front). i removed and re-soldered the connection and all is well.
many thanks
brendan
