Hi all, Help wanted, I got a 2002 C180K I have a misfire on P0301. I took the coil off and swapped it with number 2, I was going to replace all spark plugs when I removed cylinder 1 there was oil below so I just deoxidized the old one and put it back still misfires, then I checked the coolant and found black oil in it and very low coolant level still not overheating, what is your best guess valve gasket, or oil cooler seal or both, anyone else had a similar problem? I only just got the car and had also added fuel system cleaner.
