w203 (2004) c220cdi intermittent start issue getting worse
tordofm
South East Kent
c220cdi w203 est, command, elec climate, parking sensors, leather, BT phone, heated seats, auto L&W
For the last 2 months I have had 3 or 4 occasions whereby the engine does not start but it turns over for a few seconds until I stop it. On the next turn it works fine (within 1/2 a second). Tonight I tried 4 times but it never fired up (engine was cold), I left it for five minutes and put my basic OBD tool on it and no codes. I tried it again and it started without hesitation as it normally does.
Does anybody have any thoughts before I take it for a star checkup?
Marc
Ignition switch (EIS)?
Air leaks or low fuel pressure can produce similar symptoms, but the car usually starts after a bit of cranking, rather than not starting and then starting instantly on the next try.
Thanks for all the advice, as I am more electrical than mechanical I think I will get it put on a star diagnostics machine asap and will report on what codes are hopefully showing up.
Marc
I just got my local MB dealer to run star on the car. It cam back with:
2043-001 check component B6/1 (camshaft hall sensor) no signal
2043-002 check component B6/1 (camshaft hall sensor) signal faulty
The code had been logged 60 times (much more than I had expected) and I was informed it may have tripped when driving but it would not cause the engine to stop but would have thrown a fault code.
So not the crank but the camshaft sensor which I was told is fairly easy to change.
Thanks for your help
Marc
