Jim_Bo
Guys,
I've been having an intermittent problem with my car going into limp mode ever since i purchased it. I thought i'd solved the problem a few months back after replacing a split boost pipe.
However half way into the journey to work it slipped back into limp mode with the normal stop turn off and restart failing to make any difference. I had exactly the same problem on the way home.
A friend has his own garage so I called in to get any codes read and got the following:
2510 Check component Y77/1 (boost pressure regulator) positioner signals fault
2513 Check component M55 (inlet port shut off motor) positioner signals fault
3090 Test connection terminal circuit 87 the signal voltage is too low.
Any advice on what would have cause this, possible solutions, rough cost etc would all be greatly appreciated.
Thanks in advance
James.
Thanks in advance
James.
