w203 (54 plate) prewiring - bluetooth- phone?
parkie22
Hi all
How can i tell if my car (C 180 advantgarde 54 plate) is prewired for a MB Bluetooth Sap. The current cd player it came i with is compatible (when i press the phone button on it- it says no phone connected?_)but I'm not sure what to look for underneath the armrest if i purchased one and wish to connect?
many thanks Gaz. :D
fuzzer
Glasgow
F25 X3 20d SE
Hi all
many thanks Gaz. :D
easiest way , if your car has an aerial up the back window your sorted , if not buy a parrott kit :)
Rory
Cheshire, UK
C270CDi Estate (late 2004 facelift model)
Has the car got an armrest with a separate top part that has a UHI phone holder socket?
Pre-wiring was about a £600 option, so even a lot of cars registered to companies don't have it.
OP
OP
P
parkie22
hi mate...it has a armrest which splits into 2 compartments - but no connection visible - (it's not under the lowest compartment - towards the back on the left are small black plate/clips? - do i need to remove these?) :) ..tks
OP
OP
P
parkie22
sorry for being a doughnut...do i have to remove the clips or should it clearly be visible?
crockers
North Wilts
XC60 MY2014 SeLux Nav plus lot and lots of toys...
Clearly visible...if in the top part of the armrest you dont have the UHI adapter - then sorry you are not pre-wired...
OP
OP
P
parkie22
so i have the stereo ready for it and the ariel just no UHI - how much to get this added on or is it a much bigger job... many thanks for your assistance.
crockers
North Wilts
I'm confused - you have the aerial on back window - but nothing in the top part of the armrest....doesn't make sense to me...
Alfie
Surrey/Cotswolds
W169 A, W205 C, W451 smart
Pre wire was £400 option.
To retrofit it including a bluetooth cradle will be about £1,000. You could look at the FSE2 kit which can be interfaced with your comand/audio20 but this is at the expense of an IPOD connection.
crockers
North Wilts
Sounds like he is best off fitting a Parrot kit as said by Fuzzer
