W203 ACC ?
Bemmy
Bristol
2005 C180 W203
Hi all, I need an ACC feed from the fuse box in the engine compartment on my 2005 W203. If there isn't a dedicated ACC can I use one of the pins on the back of the Horn relay? if so which pin?
If this isn't the way to go any advice would be gratefully received. 👍
Isn't the cigarette lighter in the ashtray fed by Acc? Or is it II 'Ignition On'?
Not sure to be honest but I need something from the fuse box in the engine compartment ideally.
Open to suggestions as I have no knowledge!
Just bought some DRL/Indicator LED's from eBay. According to the seller the need to be connected to ACC in the fuse box - that item looks perfect. I just need to know where to plug it into! :)
