W203 Audio 10 refit problem HELP
Simonish
Leigh, Lancashire
C Class Coupe
HELP, I am trying to refit my audio 10 in my coupe having removed the Sont MP3 and Parrot bluetooth kit.
Simply connecting the plugs up - nothing works!!
Looking at the pinout on the becker site and comparing my plug I get confused/worried etc
my pinouts are as follows
Connector A
Pin 1 nothing
Pin 2 green/black wires (double wires)
Pin 3 yellow/black wire
Pin 4 red/blue wire
Pin 5 black wire
Pin 6 nothing
Pin 7 nothing
Pin 8 brown
This does not seem to match the becker website of
1 Speed dependant volume GAL
2 nothing
3 phone mute
4 constant 12v
5 ant trig 12v if radio on
6 illumination
7 ignition
8 ground
Help help I am very confused, I kind of remember moving a wire when it was installed but only on pin 7 though I can't find an Ign live anywhere so god knows what I did with it
bitonw
UK
Toyota Rav 4 NRG Auto
Stecker A
Pin 01 GAL an Klemme 6 von C2
Pin 02 K-Leitung
Pin 03 Telefon-Mute
Pin 04 Kl. 30 (battery +)
Pin 05 Schaltausgang (automatische Antenne)
Pin 06 Kl. 58d (Licht)
Pin 07 Kl. 15R (ignition +)
Pin 08 Kl. 31(Masse -)
Stecker B
Pin 01 Lautsprecher hinten rechts +
Pin 02 Lautsprecher hinten rechts -
Pin 03 Lautsprecher vorn rechts +
Pin 04 Lautsprecher vorn rechts -
Pin 05 Lautsprecher vorn links +
Pin 06 Lautsprecher vorn links -
Pin 07 Lautsprecher hinten rechts +
Pin 08 Lautsprecher hinten rechts -
Stecker C(Audio10/APS30)
Pin 01 Innenraum CAN High
Pin 02 Innenraum CAN Low
Pin 03 Rückfahrlicht
Pin 04 Wake up D2B an CD-Wechsler/FSE
Pin 05 + Versorgung CD-Wechsler
Pin 06 - Versorgung CD-Wechsler
Pin 07
Pin 08
Pin 09
Pin 10
bt
miro
Sydney NSW Australia
W203 slightly modified
Connector A
Pin 1 -
Pin 2 DIAGNOSTIC LINE
Pin 3 MUTE
Pin 4 +12V
Pin 5 ANTENNA
Pin 6 -
Pin 7 -
Pin 8 GROUND
The car has canbus so not all of those lines are needed as the information is transported over the car network to Connector C via CAN-H and CAN-L
bitonw
UK
Good news, but how did you solve it? Pls. tell us so others can learn from it.
Thx.
OP
OP
S
Simonish
Leigh, Lancashire
C Class Coupe
I made sure my wires matched that which Miro posted, changed a fuse :eek: which blew latterly and hey presto thanks to you all
