W203 Audio 50 APS
mtgraphics
1991 W124 230 CE
Hi, I have an Audio 50 APS system in my 2006 c class, it has the telephone install in the centre armrest, I don't have a handset for this and I'm sure it's well out of date anyway.
I would like to be able to play music through the cars system from my android phone, is there a way of doing this? Bluetooth or aux, I've checked the glovebox but there isn't an aux socket in there.
Could there be any connections I could use where the telephone kit is?
Any advice would be appreciated, I'm not very tech savvy but can follow instructions :D
You could retrofit COMAND NTG2.5, it has built-in Bluetooth that replaced the Convenience Telephony option in the centre arm rear, then add something like this:
EDIT: just saw your post, if this device works with Audio 50 APA then it should be fine.
Even if you did have a genuine MB HFP unit for the connection in the armrest it will not stream music etc. It is for telephone only. Loads of stuff available out there , but getting it to work can sometime be a challenge.
Best of luck 👍
