c270_w203
- Mar 21, 2009
- Location
- Nottinghamshire
- 2003 C270 Avantgarde SE Saloon, 2008 A4 2.0Tdi S-Line SE2 (B7)
Hi there, my factory-fit Bi-Xenon headlights have BOTH stopped auto-levelling at startup and are aiming too high, making me really popular with oncoming traffic They also appear to flicker (not on and off) but more as if they're bouncing at the top limit.
I did have some recent work done on the suspension with all control arms replaced and the drop links too, together with the rear springs replaced but this was all done to pass an MoT, which it since did so I'm sure the lights were self levelling still after that work was done and the lights were obviously good to pass the MoT (with no advisories too )..
I've checked both the front and rear headlight level sensors on the anti-roll bars and they seem intact and correctly positioned. (see pics). I've also checked the 7.5 Amp fuse #51 and that's fine..
I've sprayed the links with WD40 and the electrical plugs with an electrical cleaner spray (Servisol IPA 170) to no avail..
The battery has not been disconnected AFAIK and there's no EML on..
Have seen other posts that conclude the lights will fall low if the sensors fail, but mine's the opposite and it's both lights..
Any other ideas I can check as a non-expert or are we talking about a trip to dealer to see what STAR says ? Is it possibly a SAM relay etc ??
It may seem like I'm an expert, but just did lots of research on here and other forums before posting so as not to waste you clever lots time.
