Mbc1802007
Dear All,
In short: I have a battery drain issue under resting condition of about 0.85Amp (850mA). Battery was replaced two weeks ago. I did the fuse test and only fusenumber 57 after removal showed the draw current to 0.65Amp. I do not have memory seat option. Alternator giving 13.6 V on starting for stationary vehicle.
Full story: Trouble started 3 months ago when suddenly I found my car battery dead. I located the cause to be alarm battery which made the blinkers on. Following this, I booked an appointment at an MB dealer which was given almost after 2.5 months. In the meanwhile one day I smell bad from the AC (pee like). Following that I had covid and stayed inside the house for two weeks. The car was flat and will not start (so jumpstarted). I kept noticing that my battery would drain quickly. Red battery sign will appear in the morning while going to work and disappear in the evening while coming back. Finally, went to the MB dealer.
MB dealer found the alarm to be faulty and also replaced the main battery of the car (700 Euro total). After two days, I noticed the red battery sign appeared again and then I immediately took it to the dealer. He re-inspected the vehicle and said that the engine from where the oil goes through needed modification and it was never done on this car. He guessed that this could have damaged the ECU causing the red battery sign. To fix he said anywhere between 2500-3500 Euro (which made no sense for an older car). One of the mechanics at the dealer called me personally and suggested to do the repair with outside garage. Just to double confirm, I do not see any other message at the display apart from red battery sign in the morning.
I went to my usual garage which cleaned up all the excessive oil from all the places and also attached the modification cables. Unfortunately, the very next day the red battery sign was back. Then I did my own test to check the battery drain. I put the car to rest for about 1 hour and checked the drain and it was 0.85 Amp. I removed all the fuses and relays from hood, driving side and the boot (one by one). Except fuse number 57, I found no change in current. After removal of fuse 57, the drain was still 0.65 Amp.
The car drives perfectly, starts perfectly and I have not noticed any other issue as such. Just before this situation, I did change the tires and changed the oils etc.
Any help is appreciated. Thanks a lot.
