EricManchester
- Mar 19, 2014
- C200
Hi guys, I recently noticed a LOW temp issue with my W203 C200 CDI (with DPF) coupe.
After engine starts, the temp gauge slowly rises to about 80'C (never exceed it) but only keeps there for a few minutes and then drops to around 60'C. The temp may rise again to 80'C in traffic or with some harder accelerations, but always drop to 60'C and keep it there; even when driving on Motorway with consistent speed; say 70 MPH.
I had read some threads and most of people found it was due to the bad thermostat. The thermostat is cheap enough to buy but my local garage quoted me £100 for labour. However they also advised me to do the diagnosis first to make sure it is the thermostat problem. The diagnosis will cost a further £40.
I am just wondering that if it definitely sounds like a thermostat issue so I should change it w/o the diagnosis?
Also some threads mentioned that it will be only 1/2hr work to change the thermostat, could you recommend any good garage to do the replacement in/near Manchester? Many thanks in advance.
