Afternoon
I have an issue on a 2003 C230K coupe (40k miles)
The automatic gearbox seems to not be changing correctly - best described as jerky/lurching occasionally (at its worst it almost feels like the car rocks when it goes into gear, if that makes sense!)
It's recently had a fluid change, which has improved it a little - but its annoying
Any thoughts/help appreciated - only code on Autel scanner is P2315? Not even sure how or if this relates to the symptoms
Mark
Mark
