W203 C270 cdi Bolt ons
Yes there is,
You can get the c30 amg injectors, use a bigger map sensor from another later om651 engine, use the 320cdi om613 turbo, I've had mine hybrid too. Bigger exhaust, and better intercooling
Also fuel pump from a v8 400cdi and supporting mods are needed to fit the pump. Also better rail pressure sensor, all of the mods with need the map modified to allow them to work,
Have you a power figure in mind/target?
You wouldn't need all the parts above to reach C30 power levels..
