Replace the gearbox mount at the same time, it’s cheap and easy to do.Happy new year!
Are there any gotcha’s on changing the Left and right engine mounts on a w203 c270cdi?
Is it just a simple case of the front wheels onto ramps with a block of wood under neath the sump with a jack and then replace?
Thanks in advance!
Could you share the part numbers for these mounts please? Are they different for right and left?Happy new year!
Thanks in advance!
Hi - The driver side mount upper bolt has hardly any space - do I need to remove the Cat and turbo?Replace the gearbox mount at the same time, it’s cheap and easy to do.
