Neil Mackay
- Nov 17, 2011
- C32 AMG Estate
Hi Guys,
Ive recently changed my '03 dual digital climate panel to a '53 dual control from a C320. Since then, I have struggled to get the temperature to go to "Hi", it goes warm from 21 degrees upto about 25 degrees and then blows cold again as you go up towards "Hi". Question is, do panels need to be coded to the car by STAR, or are they plug and play. If plug and play, what could the problem be (im assuming blending flap actuator) and how do you get into the diagnostic settings on the climate panel and what should the panel display once in diag mode.........
Neil
Neil
