2006 DPF 220
A few weeks ago I noticed when driving on the motorway approx. 70mph there was no kickdown, and then the kickdown would back.
Recently when driving on the motorway the kickdown does work and then stops working after a little while, the car drives ok and displays no codes.
Cannot hear the turbo when kickdown does not work.
Does not go beyond 3000 revs.
If I stop the car and turn off and restart then all ok again until driving high speeds again.
Recently done a oil, oil filter and air filter change.
Tried to check hoses and seem ok, any other advice some one can offer of which hoses it could be and where they sit?
At one point engine light came on and displayed p1400 code DPFE sensor, replaced the dpf sensor and erased code.
Seemed ok from then but same problem with no kickdown \ power after driving a bit.
I have read possible leaky hoses, Maf sensor, erg valve or accel pedal sensor.
I will find a STAR diagnostic indy, just would would like to investigate myself first.
