W203 Cig Lighter
J7NNO
2012 ML350Cdi
Does anybody know how to get to the back of the cigar lighter in a W203 Saloon. I want to install a second socket under the passenger seat for fridge/dvd player etc. It looks like the entire centre console has to come out which I cant believe.
Or can I ................... :rolleyes:
Nice one fuzzer - when it stops raining I'll give it a go . Thx.
Fuzzer.
Quick thought though. On my car the cig lighter is in not in the ashtray its in the little cubby hole between the armrest and gear lever - do these instructions still apply ?
J7NNO said:
Fuzzer.
If its just the pre facelift like youve got , you just need to take the surround off at the gearleaver.
open the ashtray and you need to pull up on the edge of that trim there . its secured by two steel clips at either side so might be a little tight . it will come up just beyond the clips and then pull it forward to release it from the plastic retainer on the oppisite end( end closest to the armrest) . Once up look for the cable described above and should be plain sailing from there.
I used scotch blocks to tap into it. you can get them from halfords for a few pounds , i used the blue 15a ones. remember to run an inline fuse too.
Got in thanks Fuzzer. :bannana: :bannana: :bannana:
You sure have to be brave though!!!!
Nah , just a little crazy :) ive almost had most of the car apart :D kinda gets easier the more you do it.
