w203 Climate Control no A/C can't find errors
joncav
2004 c230
Hi - This is my first post. I just bought a 2004 Mercedes c230 - with the manual climate control system. The A/C won't blow cold and I need help getting the error codes, and resetting the system. I have tried:
  • REST + Defrost (buttons, holding down) this only produces two digit number on left, and alternating 2 or three digit numbers or E.
  • Recirculation + REST (buttons, holding down) this only produces a few G and number codes that make no sense to me.
  • Defrost + Recirculation (buttons, key in, second click, hold till flash, wait to stop flashing - waited for 20 minutes) these never stop flashing and seems the climate control keeps cycling through modes.
I'll put the list of numbers and codes from the REST + Defrost buttons below to see if they make sense to anyone.
Finally my questions are:
1. How do I get the real error codes on this system?
2. How do I reset the system, as mentioned above the Defrost + Recirc buttons never stop flashing (so I guess the reset doesn't finish?).
3. How to make sense of the codes from the holding the REST button down?
I upgraded the panel to the W203 version with digital display. The A/C has never worked but in hopes it was a small problem I bought the digital display to get more info. Codes were:
00, 89
01, 32
02, 68
03, 116
04, 116
05, 116
07, 9
08, 100
09, 0
10, 90
11, 30
12, 30
13, 30
14, 30
15, 30
16, 0
17, 0
18, 32
20, 0
21, 65
22, 0
23, 0
24, 123
38, 100
39, 100
40, 100
41, E
42, 0
43, E
44, 100
45, E
48, 100
49, E
50, 49
51, 4100
52, 1300
58, E
59, E
60, E
61, E
70, 1
71, 0
72, 0
73, 0
74, 0
75, 0
76, 0
77, 0
80, 1
81, 0
82, 0
83, 0
84, 1
85, 0
86, 0
87, 0
96, 4
97, 70
98, 0
99, 66
Pressing Defrost+Recirc attempts to reset the air distribution flaps.
You need get the error codes read using STAR.
Hey @HughJarse Thanks. I'm not sure but because I just got the car but when I tested the High side with a cheap gauge it was high. Do you think it might be overfull or do you think I should have the A/C vacuumed out and refilled with new refrigerant?
Thanks again for the reply.
Jon
