I have w203 c class I believe it is command v2 unit .The nav was working intermittently. ie. I started the car, the Nav splash screen would load and would say no disc inserted then half way through the journey. The cd slot seemed to start recognise the nav cd and the maps would load up ok but it would never eject the CD.Other day I pres eject and it was my first time to see the CD eject so I just looked at the CD, then ever since I put it back to the slot above the screen (where it originally came from , as I have 6 CD changer on glove box). Now the command system , as soon as I press the Nav button it doesnt even think that the CD is there and says no cd inserted immediately other then a few clicks and whirrs .I looked on the forums today and it seems common problem with the platten roller getting slipperly after accumulating grime/dirt. I can use a butter knife or something to lever the slot to help press the CD against the roller to hopefully spit it out.I also looked on DIY how to dissassembly but does this mean I need a whole new command unit? or just the cd section is replacable as my screen is OK?
