Hello Guys, W203 pre facelift. It started with the window working when it felt like it. Then it stopped working altogether (luckily closed)
I unclipped the door card, and without de-hooking it. stood it on a box on it`s end.
Suspecting switch failure, I unplugged and removed the switch cluster, took it apart, but could not find anything wrong with it. The inner metal switches all clicked normally and the printed circuit looked fine.
I reassembled the door, making sure all the wiring plugs were secure in the module, but the window problem was still there.
When I came to lock the car, I found that the fob would only unlock the driver`s door and would not lock it.
To make matters worse, everytime the car starts moving; a bleep and a red dash warning that the door was open.
To cut a long story short, I suspected and changed the door module, but the symptoms remain, but strangely, the window occasionally works!!
Any ideas ?
Any ideas ?
