PhilL
- Aug 31, 2003
- Location
- Bristol
- 2002 SL500; '54 E270 CDI Elegance Estate; 2001 C200K Coupe
Took a run to London yesterday in my wife's C200K Coupe. On way up air-con seemed to work fine but around Marble Arch noticed EC button was lit and car was getting warm. I thought my wife had switched off, (I like the car cold when driving but passengers often forget their hats and coats) but on setting off for home found I could not switch AC back on; EC button remains lit.
Sweated all the way down the M4 with sun blazing straight into the car.
Investigated today!
Manual says EC will light if gas is low but I topped it up a few weeks ago, so got out the bottle of R134A and gauges. Pressure in system as expected but compressor still will not run.
Checked on Detali.ru to try to identify where the pressure switch is. To my surprise found no mention of pressure switch. Had a rummage around the engine bay (surprising how little room there is under the bonnet, even with a 4-cyl) and found an electrical connection to a 4-way unit at the bottom of the condenser identified on Detali.ru as a temperature sensor. removed, cleaned and refitted the connector, but still EC lit.
No warning lights on but connected my Gendan EOBD with Engine Check software and had a play monitoring live values and graphing various engine paramaters. Didn't help but was fun for a while.
2 hours later and none the wiser, almost called MB Bristol service dept; but thought I would wait until the full power of the forum could be brought to bear on my problem.
So: EC light permanently on, gas in system, no warning lights but no cooling. Any suggestions would be very welcome. Only 2 days before I have to make that call!!!!
Investigated today!
