TheMOTman
Anyone point me in the direction of a decent wiring diagram for the engine management for a C220 CDI 2005? As usual AutoData is useless.
Fault code coming up as dpf sensor (pressure differential) e.g pipes/hoses blocked/split. Goes into limp mode, clear fault and all is well for a few mins.
DPF sensor is brand new. DPF is brand new. Pipes are clear, not split, not blocked. Sensor has 3 wires, just wondering what's what and where they go so I don't have to cut the whole loom apart.
I assume one is ground, one 5v reference and one signal wire? Pin 1 Red/Green, Pin 2 Brown, Pin 3 Yellow/Green
One of them has to be open cct...?
