W203 flat battery - central locking problems
mark gregory
Hi, I have a 2005 C200 CDI, last night I left the keys in the car and flattened the battery! I jump started the car this morning and now the central locking won't work. The car drivers door opens with the key insert and the car starts and runs ok with the plastic key, has anyone any idea what would stop the car receiving the signal from the key fob? Everything was fine before I flattened the battery and I've put new batteries in the fob but the central locking still won't work. Any suggestions great fully received. Thanks Mark
OP
OP
M
mark gregory
Folks, spent half an hour on here researching similar threads and as of five minutes ago found a blown fuse in the rear fuse box. All now seems to be fine and I'm chuffed it's sorted without costing a fortune! Mark
carat 3.6
In the workshop
S124 E300d wagon, W124 om606 monster, E46 v8 coupe
Glad you got it sorted out, welcome to the forum by the way. :thumb:
Chrishazle
Nr Ashford, Kent
2008 S204 C220CDI Elegance Estate Auto, 2008 R171 facelift SLK280 Auto.
Suggest you also research jump starting W203's - you've got off light, only a fuse rather than a rear SAM! They do not like current surges, such as those you can get from jump start packs or another car's battery, engine running.
