If i had the money spare and it was available for my car I would do it,Looks quite snazzy1998K said:Thanks Bobby Dazzler!
So it seems that it's only a matter of changing the armrest cover, may be
Does someone consider useful this modification on a pre facelifted W203?
thanks again
pluggers said:If i had the money spare and it was available for my car I would do it,Looks quite snazzy
Bobby Dazzler said:"Snazzy" is best translated as impressive or cool in this scenario.
1998K said:Are there any differences and improvements between pre and post facelifted W203?
thanks a lot
Bobby Dazzler said:IIRC Post-facelift can hinge left or right (clever double hinge). Pre-facelift hinges at rear only.
Also cup holder aperature is slightly but irritatingly smaller in the post-facelift cars.
HTH
I'd like some of those. The cup holder I meant is the one beneath the roller cover - between the arm rest and the gear selector.miro said:Cup holders are actually a fold out item which store into the space provided. Quite nice actually.
Bobby Dazzler said:I'd like some of those. The cup holder I meant is the one beneath the roller cover - between the arm rest and the gear selector.
miro said:There are 5 versions of the armrest.
1. Early non phone version
2. Nokia version for cars with COMAND (hinge at back)
3. Updated UHI version with side opening
4. Same as 3. but no height adjustment
5. Revised UHI version that opens like 2. and no height adjustment.
1998K said:you are the boss of the armrest
Please what does it means "UHI"?
thanks
have you performed any sort of armrest modification on your W203?
miro said:My car had #1 and now has #3. Due to colour changes it is not possible to fit other models to my car given that I now have a phone in my car.
Thankfully the 2005 armrest design was sold in the last of the 2004 cars hence they are available in a wide range of colours both pre-and post-facelift.
Later designs #4 and #5 are only sold in 2005 colours which do not match older cars.
If you dont know what UHI is then you may not need the newer armrest ! It is the current universal phone system.
1998K said:thanks Miro, so according what are you saing me, there is not a armrest with side opening WITHOUT phone system/inteegration.
PS: totally OFF topic but since it seems you know , do you know if factory subwoofer in the rear parcel is feed directly from the radio or from a suitable amplifier? I'm going to install my Alpine with factory speaker. THANKSmine is the system equipped with the radio Audio 10 cassette
perdikoyla888 said:Factory standard subwoofer feeds straight from the car stereo. Unless you have premium sound system BOSE/HARMON KADON where the subwoofer plugs to the rear fibre-optic amplifier. I hope this helps
miro said:You can install the armrest without the obligatory phone equipment and just have a really expensive empty tub.
Dont forget to order the underside cover also ... not included.
Dont install Alpine .... get a navigation unit instead. The COMAND Navigation improves sound quality from the stock radio.
