W203 Glass mounted Antenna position
High-Lo
Kent
2013 X166 Mercedes GL350, Porsche 911 Carrera 4 Cabriolet, Porsche 968 Cabriolet
Hi all,
Has anyone got one of these on their facelift W203's? More commonly found on 2005/06 models. I just need to know if the antenna base is mounted with the longer side of the base positioned at the top or the bottom. Can anyone check for me please?
OP
OP
High-Lo
High-Lo
Kent
Just checked mine - the short side of the base is at the top
Thanks very much mate :)
Strangely I've seen it the other way round too so guess there isn't a standard way.
fatdazza
Cambridge
Vauxhall Chevette
Mine is the estate so may account for it? May however just be whether the guy in the factory fancied it one way or the other:D
fatdazza
Cambridge
Vauxhall Chevette
Are you able to confirm if the "stick" element of the antenna unscrews?
Mine appears to have been chewed and although it works perfectly, it upsets my aesthetic sense and I would like to get it changed.
Previous owner must have taken it through the monkey enclosure at the safari park! (We always take the wife's Focus when we go!)
OP
OP
High-Lo
High-Lo
Kent
Yep sure does unscrew. £20 for a new one :)
ghummy
England
Mercedes Benz c220 (w203 2005)
how funny that you should say that. i have had mine chewed by a cat a couple of days ago. i say a cat because it left paw prints all over the bonnet, windscreen and roof...lol
OP
OP
High-Lo
High-Lo
Kent
Hey Ghummy would you mind checking which way up yours is if you have a saloon? Cheers :)
ghummy
England
yes i have the 2005 saloon, i will check for you tommorow morning if thats ok matey...
OP
OP
High-Lo
High-Lo
Kent
Many thanks matey
ghummy
England
the wider part of the antenna is at the bottom whereas the narrower is towards the top...
OP
OP
High-Lo
High-Lo
Kent
Cheers Ghummy much appreciated!
removed
Guest
Thank you High-Lo, your post prompted me to do a little search on glass mounted antennas and subsequently found out these are easily removable :thumb: - I had a really ugly one and was certain I cannot touch it for fear of cracking the windscreen :doh: :doh: :doh: :wallbash:
My windscreen is now clean! :bannana: The inside part will be removed tomorrow ...
Not even sure what that antenna was: a part of Nokia setup (already removed) or Blaupunkt DAB - either way it's gone and I'm happy :cool:
