C250TD_Auto
Hi all,
looking at buying a W203 C270CDI Auto (Elegance) with 146k on the clock.
I've been in touch with Mercedes and it was built 15th October 2004, registered 4th Feb 2005 so it shouldn't have the Valeo radiator issue (my understanding is Merc didn't fit the Valeo radiator starting Quarter 4 of 2003). So that's a tick in the box.
It's been serviced regularly so that's another tick in the box -
As it's 2004 build it should be galvanised - tick in the box -
I'm aware of the thermostat issue but I can check this by checking kick-down and if it'll rev OK over 3k (so i'm told) - but this can be a DIY So i'm not overly fussed - more of a bargaining tool if it's evident.
I know the engine will go for a lot more (I have a 1.9TDI VAG engine which is fine @ 152k)
But Mercedes have no record of a Gearbox fluid change being done and there is no paperwork with the car to suggest it's been done either - so the big question is whether the fact the gearbox oil hasn't been changed is an issue. Mercedes have quoted me at £302 all in - which I can live with (the dentist fleeced me for £450 this morning!) - The gearbox is my main concern, the car is a great spec and my drive to work is A roads doing between 50-60 so it's not going to have a hard life
Any advice on the gearbox would be appreciated
I've not viewed the car yet so i'll need to ensure the changes are smooth and no clunkings etc
Thanks for reading
Thanks for reading
