Deker
Can anyone shed some light on a problem I have with my car, it starts fine in the cold weather but for the first half mile to a mile it has poor throttle response (it's as if the 'choke' isn't being applied), is there a separate temperature sensor for the cold start or are there any other known problems that cause this?
The temperature gauge seems to be responding correctly (reading around 85 degrees under normal operation) but I'm not sure if this sensor is the same one that the cold start circuit would use?
My cars is a 2006 180K w203
EDIT:
Just to add some history, in a previous post I had a few other problems here, regarding an sensor circuit, this was a faulty lambda sensor, since I replaced it there hasn't been any fault codes so now there is just the cold running problem
Thanks for any advice
Deker
EDIT:
Deker
