W203 key or ignition problem
EricManchester
C200
My 2005 W203 recently developed a start-up issue, but I am not sure what's the exact problem.
Normally, when I insert the key and turn to position 2, the dash panel should instantly light up.
However, sometimes the dash panel doesn't light up at all; or it delays for a few seconds before lighting up; or it does light up first but then dim for a couple seconds, before the lights come back again.
In any of these occasions, if I go ahead to start the car, the engine will start straight away but cut off within 1 minutes.
However, in the same situation; if I remove the key and insert again without seeing above symptoms at position 2, the car is fine.
Anyone could suggest what the likely problem is? Cheers.
DSM10000
Near Salisbury
E32O CDi Sport, MX5 1.8 Sport, RR 4.2 SC
You really need a Star diagnosis, do you have a good MB independent nearby?
OP
OP
E
EricManchester
C200
Thanks for your reply.
Yes I did a Star diagnosis in my local garage but been told that there was no code for it.
