W203 Lowering Springs.
thebassman
NORTH EAST
C280 AVANTGARDE S.E.
Hi, need some help please, my 56 plate C280 Avantgarde SE has always been lower at the front compared to the rear and I would like it to have a more level stance ( I never have rear seat passengers) I am considering purchasing a set or rear Eibach springs to lower the rear by 30mm but my question is that I know the Avantgarde SE has Sport springs fitted as standard and wondering if these springs are shorter from new and therefore it would be pointless buying lowering springs as these would be the same height !!
Any help would be much appreciated. Thanks.
You can change just the spring pads at the rear if you want to level it out.
Can we see a pic?
Hi, thanks for reply, by spring pads I assume they must be what the springs will sit in, haven't actually looked at the springs closely and was not aware that these pads could be changed for shorter ones. I have tried to attach a photo but it has failed as the file is too large !!
There are 4 sizes available being 5, 9, 13 and 17mm each having 1, 2, 3 or four dots on them in that order.
Part #A2103250184 to A2103250484
