chantaiman
- Jul 18, 2013
I have a 2001 W203 C200 Kompressor with M111 engine.
The rear headrest release and headlight level adjuster are inoperative.
Since both systems run on vacuum I think they are the result of a single failure somewhere in the vacuum source.
Can someone spend a little bit of time describing the vacuum system on this car ? A schematic and component location will help a lot.
Both systems used to work but only with the engine running, so I assume they run on engine generated vacuum but not a electric vacuum pump.
Thanks for helping.
Kelvin
Thanks for helping.
Kelvin
